Hi all,
I have a scene, which I would like to have triggered if one of certain switches changes the value.
obviously, I could do
{   operator = "any",
    conditions = {{
        type = "device",
        id = 22,
        property = "value"
        operator = "anyValue",
        isTrigger = true
        type = "device",
        id = 42,
        property = "value"
        isTrigger = true
Is there a better way for this like
    type = "device",
    id = {1, 2},
    property = "value"
    isTrigger = true
the second option does not seem to trigger the scene but is there something more elegant?
Already asked before
Id in int and you can’t provide any others value here
Ps: more elegant do not dup Ids in definition conditions and code it’s really annoyed when is should setup I’d in conditions and use the same values in code more than I can’t used HomeTabke in condition
    Thank you for being so active and helping. I really searched and I am still unable to find anything about it. Would you have any pointer (sorry for that)?
    The other point you made, I did not quite get. I would like to avoid having a long list of conditions but if a scene is supposed to trigger if one of 20 switches changes value, I do not see another solution for that. If there is one, I am the first to use it :-)
