  • 5
SCENE. How to write to InfluxDb
10der
a special thanks @tinman ?
  • Like 3
/monthly_2020_06/grafana.png.75e34df6ebeb73619b4d174df798fccb.png" />
and Icon from HC2 user ;-)
Guest DigitalT
@10der
Love the script, thank you!
Some suggestions to add for newbies like me in both HC3 and scripting,
-  What to add into declerations?
- Add examples in comments where to change or add multiple devices?
- Add a example of the expected URL to influxDB from the script
- I also use InfluxDB protected with password so I added the variable and changed this in the code  :
Dear, I have copied and pasted the script into a scene edit window but cannot save it. Am I doing something wrong?
On 6/1/2020 at 9:03 PM, drboss said:
Honestly i am newbie and was not aware about it. Actually i found a declaration script, saved, but getting following error message: [23.03.2021] [18:42:04] [DEBUG] [SCENE12]: {"data":"{\"code\":\"unauthorized\",\"message\":\"Unauthorized\"}","status":401,"headers":{"Content-Length":"48","X-Platform-Error-Code":"unauthorized","Date":"Tue, 23 Mar 2021 17:42:00 GMT","Content-Type":"application/json; charset=utf-8"}}
Thanks for prompt reply, indeed I have login and pwd, actually i have set it in the script using local dbUser and local dbPass and have also adapted the local url
 local url = "http://" .. host .. ":" .. port .. "/write" .. urlencode("?db=" .. dbName) .. ("&u=" .. dbUser).. ("&p=" .. dbPass), but still facing this error. Would it be better to have influxdb without login/pwd?
It would make it somewhat easier
Thanks, but actually it looks like login/pwd is mandatory on influxdb (at least what i am using, on docker).
Thank you, but still getting error message. Actually i have a HC3 and my influxdb is running on docker (NAS Synology). A bit lost with this error message.
I have set login/pwd accordingly, but still not working.
[27.03.2021] [21:34:19] [DEBUG] [SCENE15]: {"status":401,"headers":{"X-Platform-Error-Code":"unauthorized","Date":"Sat, 27 Mar 2021 20:34:19 GMT","Content-Length":"48","Content-Type":"application/json; charset=utf-8"},"data":"{\"code\":\"unauthorized\",\"message\":\"Unauthorized\"}"}[27.03.2021] [21:34:19] [DEBUG] [SCENE15]: Wrong status '401' in response!
@claudent I do believe that the difference is what version of Influx you are running. I have two RaspBerryPi, one running InfluxDB 1.8 (32bit) and one running InfluxDb 2.0 (64bit).
I see the exact same error messages on the InfuxDb 2.0 which is related to that this version have a different authentication system. I have so far not been able to solve that and have given up and only use the InfluxDB 1.8.
2 hours ago, claudent said:
I get it to work with influxdb 1.8, thanks alot.
Nice to hear that it worked!
Hi, maybe stupid question but does this run locally so that you should have influxdb and grafana on e.g. a raspberry?
