informations duplicate in RefreshStates
hello,
somebody knows why some informations are duplicate one the panel RefreshStates in the API ?
For example :
- state of PIR
- state of switch
when one state change, I have 2 records, with the same value, but with an another ID (of RefreshStates)
4 answers to this question
State of PIR and Switch?
Might be you change switch by PIR motion somewhere?
Could you post refreshState screen shot?
    All excuse, it's not in "RefreshStates" panel but in "panels/event" !
    and here a print screen :
    And I just realized that there is a difference  (green arrows...)
    /monthly_2020_06/image.png.c6e86fb5881b19a317e6cbbf06bf393d.png" />
    I'm sorry... ... ...
    OK... now it makes sense.
    The id is the id of the event, not the device.
    Regarding properties "value" and "state", in case of switch they are the same, but if (for example) is a dimmer, then the state shows on/off (true/false) and in case of "value" is the dimmer level (0-99)
    So everything looks correct.
    Let me know if you've more questions
    Edited by cag014
    Thanks,
    I understand chapter with the IDs.
    And now I understand the difference between "State" and "value"'...
    I didn't think about it...
    thank you !!!!! :)
