philipperoger 0
Gregory says "The implant heats up, this temperature is adjustable through the offset temperature options".
But where are the offset temperature options? They are not indicated in the Smart Implant manual. I also use a Fibaro "eye" motion sensor with a built-in temperature sensor, and there I could adjust the temperature offset (parameter No 66). I could not find the equivalent parameter no in the Smart Implant.
