Tricks: Balancing HC3 load during minute
Hi all,
Want to share - it may be useful for your HC3 to balance CPU load.
I have several QA working every minute ( power control, data export, etc.. ) and I started to give every QA their own time space during "one minute" time.
when QA starts, it wait till right second, which I define in secondToExecute - before start.
for example - export to Influx start on 30th second within one minute.
and main loop also calculate how much seconds taken by all routines and correct "sleep" time to run again on 30th second
As I know, Fibaro & LUA can't provide milliseconds timing, so - it can be some un-sync in time, because milliseconds give some extra timing.
But this is not dramatical situation - solution can be - restart HC3 every 1 week to restart all QA's and sync them again to their timings
Code example below:
function QuickApp:loop(refresh)
    local timeNow = os.time()
-- any code to run
    loopSeconds = os.time() - timeNow
    self:trace('loop seconds = '..loopSeconds)
    fibaro.setTimeout((refresh-loopSeconds) * 1000, function()
        self:loop(refresh)
    end)
function QuickApp:syncTime(timeout)
    local secondToExecute = 30
    self:trace ("now is "..os.date("%H:%M:%S").." | trying to sync to "..secondToExecute.." sec" )
    timer = secondToExecute - ( os.time() - 1591477200 ) % 60
    if timer == 0 then
        self:loop(timeout)
    elseif timer < 0 then
        timer = 60 + timer
    self:trace ("need to sleep "..timer.." sec for sync" )
    fibaro.setTimeout(timer * 1000, function()
        self:loop(timeout)
    end)
function QuickApp:onInit()
    self:debug("Starting... QuickApp Init")
    self.loop1timeout  = 60
    self:syncTime(self.loop1timeout)
@afendikov Kostya, actually @jgabJan already said about this.
please use setInterval(function() self:updateWeather() end,1000 * 60 * 15) -- 15 minutes
    It doesn't work for me without correction:
    [07.06.2020] [11:50:31] [TRACE] [QUICKAPP309]: lastUpdateTS :1591519830
    [07.06.2020] [11:50:38] [TRACE] [QUICKAPP309]: loopSeconds = 8
    [07.06.2020] [11:51:38] [TRACE] [QUICKAPP309]: lastUpdateTS :1591519898
    [07.06.2020] [11:51:43] [TRACE] [QUICKAPP309]: loopSeconds = 5
    [07.06.2020] [11:52:43] [TRACE] [QUICKAPP309]: lastUpdateTS :1591519963
    [07.06.2020] [11:52:49] [TRACE] [QUICKAPP309]: loopSeconds = 6
    I used     setInterval(function()
            self:loop(refresh)
        end, refresh * 1000)
    where refresh = 60
    But main post was about to start QA in exact second.
            self:loop(refresh)
    where refresh = 60
    Start on even second (+ optional offset). This doesn't loop, just start a function at specified time.
    To loop without drift just do this
    To loop 15s past even minute do
    There was another post here how to patch setInterval to get a drift free version.
    • Like 3
