JcBorgs 52
Have made some tests with ‘Profiles’ in the HC3, but it ended miserably with a crashing HC3.
The intention was to use Profiles (Home & Away) to execute a lot of things instead of putting the actions in different scenes. So had two simple scenes:
- one that executed on when the house is armed, the only action was to set Profile “Away” as the active profile.
- one that executed on when the house was disarmed, the only action was to set Profile “Home” as the active profile.
Then in the Profile settings for the “Away” profile I configured that all Ceiling lights should be turned off, a scene should be enabled.
For the “Home” profile one light should be turned on and the scene that was enabled in “Away” should be disabled, and all alarm sections should be disarmed
Then did some test, armed and disarmed the house a few times and suddenly the HC3 became totally unresponsive. Was impossible to get in contact with the HC3, led on the HC3 was normal, the only way to get it working was the pull the power and restart the HC3.
