Converting a VD to QA, get stuck
Now that I have adapted half of my scenes to the HC3, I wanted to try that with a VD.
But I totally fail.
It would be nice if someone could help me there.
This VD is very important for me because it reads the LUX value from a non-zwave sensor and writes it in a global variable.
Thank you everyone for the great support here.
6 answers to this question
Hey!
It's not a solution, but maybe it's a start!
Since you adapted Lua scenes from HC2 to HC3 I assume you know Lua. The missing piece here is the Quick App knowledge.
Here is a great article about Quick Apps in Home Center 3:
Since you probably check your non-zwave device in the Main loop you look for a replacement of that mechanism. I think this is what you're looking for:
But I totally fail.
This is a start
You need to set the QA variables
user e.g.  user name
password e.g. password
deviceID e.g. 12
IPAddress e.g. ip address
TCPPort e.g port
The idea here is that the QA becomes the Lux sensor so it doesn't store the value in a global variable. Instead it sets its value property to the lux value.
That way you can trigger scenes on the value changing or calling fibaro.getValue(id,"value") to retrieve the value.
...and the icon in the GUI shows the lux value.
There may be some issue with parsing the lux value retrieved from the http request. Please review it and change accordingly.
    Hi @jgabThank you very much for your help. I'm currently trying to understand the QuickApps
    but the possibilities are many.
    I think I understood the principle of this QickApp, but I still can't find the error. I created all the variables.
    Error is: line: 31 attempt to index a nil value (global 'self')
    The line reads: self: trace ("Read:", json.encode (res))
    If I comment out the line and insert a print (data) under line 32, the output comes from the server as expected.
    Can you please have a look at it.
    Thank you very much.
    My error. change
    to
    I store the "self" variable of the QuickApp in the local variables QA so we can use all the functions defined on self:*, like self:trace etc from functions that don't belong to the class Quickapp:* ...
    I.e.  the self we have in
    'self' is a variable with all the functions belonging to the class QuickApp. We just save it away to a local variable 'QA' so we can use it in "regular" function.
    So, the QA:trace logs the result from the http request. Can you post that? I think we can get rid of the string.sub etc functions.
    Hi @jgab
    Yes that was it. But still seems to be a problem everywhere. Here is the output:
    Hi@jgabjust saw that the output is different:
