Climate Zone adding issue
Hi.
Im having issues with adding a climate zone. The Add zone is greyed out and i have 6/7 zones added.
Tried unlearning and adding the thermostat again. Resetting hub etc. Anyone got a clue how i fix this?
Also got the same problem when deleting a Zone i could not add it again.
Thank you.
12 answers to this question
    bump
    Hi @envie
    Are you logged in locally and as an admin user??
    Hi. Im doing it from home.fibaro.com on a customers hub. But on another network but im the only admin user atm.
    Hi @envie,
    Just logged on
    Used the same cloud login as the admin account on the HC3.
    Then I have no restrictions on the climate zones (adding and deleting works perfectly)
    But if a use an "user" cloud login, I cannot do anything in the climate zone.
    Does did make any sense?
    Hi.
    Did the same thing as you, but i dont get an option to add a climate zone still. I dont understand why this is happening.
    I think the best thing to do is contact support about this issue.
    I've got exactly the same issue on my HC3 ( firmware 5.050.13 )
    Did the support resolve it ?
    I have the exact same issue with HC3 5.50.13 fw.
    I am logging in with local IP, and either if I login with local/ cloud ID account to local IP I can not add/edit climate zones.
    I am familiar with the limited changes on cloud id admin webpage, therfore I always use the local IP login.
    Anyone manage to sort this issue?
    Antoine a solution? I have the same problem
    Same issue here with HC3. Add Zone greyed out in Climate configuration. No zones added.
    HC3 fw 5.130.45.
    Any ideas anyone?
    That was me being stupid. To be able to add Climate Zone you need to have thermostats. Either physical or virtual devices made up of temp. sensor and a switch/valve/actuator.
    Only then can zone be created. One per Thermostat.
    Great! How can I create a "virtual" thermostat on HC3? I have temperature sensor on each of my rooms and a Fibaro Smart Implant controlling my boiler, but I can't still add zones...
    EDIT: never mind... already found the answer (but can't find a way to delete my comment... sorry)...
    Edited by Corceiro
    Found the answer
