jwi 53
I have many HC2 scenes in which the command setTimout (functionname, 60 * 1000) is used.
The main function checks conditions such as temperature or brightness every minute. Since the
command no longer works in the HC3, I have built a while loop into the function and ended up
with a fibaro.sleep (60 * 1000).
It works, but I assume there is a better solution.
But which?
Calling up the scene every minute via a cron trigger is definitely not a good solution.
Thanks for your help.
11 answers to this question
