HC3 trigger scenes at 0:00
I have observed that the HC3 triggers my scenes within the day-change at 0:00 by hand.
The system ignores in this case all declaration and switch to a "run actions" within the scenes.
The declaration should prevent this cause my trigger intervall is starting at 7:30 and only up to 17:30:
conditions = {
    { type = "date",
      property = "cron",
      operator = "matchInterval",
      value = {
         date = { "30", "7", "*", "*", "*", "*" },
         interval = 900
    isTrigger = true
    { type = "date",
      property = "cron",
      operator = "match<=",
      value = {"30", "17", "*", "*", "*","*"}
    { type = "global-variable",
      property = "sRollEastSun",
      operator = "==",
      value = "off"
  operator = "all"
Eventlog:
[07.07.2020] [00:00:00] [DEBUG] [SCENE:R.OFFICE]: checkState | CLux: 1.0 | dLux: -9999.0
[07.07.2020] [00:00:00] [DEBUG] [SCENE:R.OFFICE]: Rolladen offen
In my case the blind will open, which should be the case when the sun is not shining on to the windows or after 17:30.
A trigger should start at 7:30 in my case, end at 17:30 and 0:00 by far smaller than 7:30, correct?
Has anyone here made similar observations?
@moltos
You need an extra condition. The matchInterval only starts at 7:30 and than goes on and on at the defined interval. This is my declaration for every hour from 6:00 and the last time is at 23:00.
Edited by SmartHomeEddy
    Thanks,
    in my observation i think we must exclude more and let less space for interpretation.
    The current documentation will have much space for improvement (+ some case sensitive wrong documented parameters).
    I have changed my interval triggers as well. Hopefully this will stop this strange behavior at night.
