QA variable and value
@A.Socha
hi!
ia any chance to have a custom variable and values for QA with device type?
/monthly_2020_07/image.png.83cbfcd8239aa8019b56e111bc7823d0.png" />
with able to choose single / multi-devices.
thank you so much!
O.
Edited by 10der
13 answers to this question
1 hour ago, 10der said:
@A.Socha
hi!
thank you so much!
O.
I think the point is that "we QA developers" have seen that quickAppVariables work well to allow users to configure our QAs. In. the best of worlds users would not need to touch the Lua code but just configure quickAppVariables to tailor the behaviours of the QAs.
The input for quickAppVariables could be a bit better, possibly allowing types or enumerations to guide the user what is allowed to be set/configured,
However, besides that, QA developers also would like to store specific/internal data associated to the QA but we don't want to expose it to end-users as quickAppVariables.
Now we try to hide data in property fields but it's a hack (some of us stuff data in the customDescription property now) and we can't create custom properties as devices are defined by schemas is seems.
So, maybe "device variables" as @10der suggests - at least something that isn't easily mixed up with quickAppVariables and accidentally deleted by a user trying to configure the QA.
oh and I forgot. Custom device properties could also be accessible with fibaro.getValue
As @jgab described I uses description.
I store device information in the description.
Or you can do with it by make dummy child QA and use setVariable, getVariable.
(because child device's QAvars not appears!)
Yes that works - but no help for QAs that can’t have children.
Can we hide child devices? Possible to set visible=false ?
    @rangee you can't catch my idea.
    i want setip my device with UI! i am not saying now how and where i can stotes id's!
    i am asking about nice setuping device.
    please click here:
    /monthly_2020_07/image.png.2569998dd8bed1a072439d30ba2b29bc.png" />
    than
    i want to setup my devices:
    like a
    for clearing undestading i am asking abou UI
    @jgab Yes. we can make child devices  visible to false.
    But it's not good because we should make 2QA(1 main QA and 1 dummy QA)..
    If QA(A) can't have children then, is it possible to  make main QA with deviceController and make QA(A) as children?
    Edited by rangee
    Add
    @10der plz calm down. I know what u saying.  I just comment jgab's reply.
    If you don't have time until fibaro update the firmware(what u suggest)
    Make QA for it.
    UI - select(single or multi) or label with button
    Variables - input vars which you want to change
    Please calm down.
    -------- add -------
    oh. linked device.  thats what i questioned before. you told me   its possible by edit lua code and you gave me a example fqa.
    it looks like same question  you and me.
    in this case,  same as above
    just make qa for it.  select sensors or switch by user defined interfaces  like image which i uploaded.
    Edited by rangee
    add
    @rangee you still not catch something ;)
    ok. Example
    you decide to develop QA
    qa working wit 1..N temperature sensors
    1..N humidity
    1..n relay
    you what to public own QA to ppl
    question how you can configure own QA?
    ok you have 2 variants
    1st - old school
    readme.txt
    please open QA and change at the top blA bla bla
    2nd - most elegant
    create 3 local var and asking user to fill this values separated by comma
    question about UI/AX it’s out fo scope ;) and how user will provide this value plus fill thing this input lines....
    so, why I asking to make nice UI for building and filling of list sensors or actors
    ok.... maybe I want more than Fibaro devs can ;)
    @10der  Yes. I explain exactly.
    Theres 2 way.
    wait for f/w update
    or make QA looks like above.
    Its same. User just select the device by click.
    But this way... Developer need to write a code a lot×100000
    what a hassle...
    Best way is  Fibaro update it  at next release...
    ps. Im not good at English.  understand plz :)
    Heres my QA... refer to it.
    user just need click and use it.
    @rangee
    Quote
    is not clear how this names populated in your QA ?
    please share your QA forme ? I whant clicking also +)
    @10der I got device information from HomeAssistant so my QA populate names via API call.
    It could be with fibaro api.. (fibaro.getDevice with filter(eg. temperatureSesnor, humiditySensor etc...))
    This is just example with personal opinion.
    And this code has lots of logical error because I wrote this just to show you.
    local device_list = {}  -- fibaro.getDeviceIds() with filter
    local selected_device = {}
    local label_show_i = 1
    -- Let total number of label is 5.
    function QuickApp:btnBeforeClicked()
    if #device_list < 5 then  return end
    label_show_i  = label_show_i  - 5 < 0 and label_show_i  - 5 + #device_list or label_show_i  -  5
    changeLabelText(label_show_i )
    function QuickApp:btnAfterClicked()
     -- same as above.   but label_show_i increases.
    function changeLabelText(i)
    for i = i, i + 4 do
    quickapp:updateView("label" .. i, "text", device_list.i.name)
    quickapp:updateView("btnSelect" .. i, "text", isSelected(i) and "remove" or "select")
    function QuickApp:btnSelect1Clicked()
    if device_list[tostring(label_show_i )] and not selected_device[tostring(label_show_i )] then
      addDevices(label_show_i , device_list[tostring(label_show_i )] )
     -- something else
    function addDevices(i, d)
    selected_device[tostring(i)] = d
    -- something else
    Edited by rangee
    edit
    Crazy.... but it’s ok
    nice workaround....
    I have ~100 real zwave device and ~20 ZigBee device in HC (via zigbee2mqrr + QA)
    just look to you pr code and thinking how users will be clicking and finding device ;)
    nice workaround....
    ya... it require a great deal of care... it's very hassle.
    I'm using this with zigbee2mqtt too.
    Image which I uploaded... is z2m QA. ( 79 zigbee devices )
    Hi, you mention, you upload images to the HC. Is it HC3? If so how do you upload them? I am searching this already for a long time and would be very much helped if you could explain.
