what type of connection Gateways whould HC3 accept?
Edited by vmation.virgin
12 answers to this question
Do not catch you question
on pic you provide your serial no oh your HC3
IP address (as I can understand you use Microtik as router)
But what about gateway?!
    can i connect another HCL, or HC2 as additional gateway for HC3?  or just supports HC3
    No. Not implemented yet
    Hi
    What is the status of this, still cannot connect a hc2 with a hc3?
    10 minutes ago, Twannie said:
    Hi
    i don't think that is going to happen
    hc3l connects to hc3 (must have same fw)
    But HCL can connect to the HC2, right?
    That's a bit different too regarding firmware?
    No, they also have to run the same fw
    Okay, too bad
    Would have been a nice way to slowly migrate which holds me back for now
    My system is too big and i have to many lua scenes so easily switch to a HC3
    thanks
    @Twannie maybe use Slaves for HC3 to make your transformation more smooth
    Very interesting, thanks @SmartHomeEddy!
    I have to learn how to use json tables first I see
    How is it with the HC3, stable for a big system?
    And zigbee not yet implemented?
    I didn’t used Slaves for HC3, I went cold turkey :-)  But the principle look great.
    My HC3 works fine, I try to keep it stable, I don’t use betas, call me chicken.
