z-uno water meter (Home Center 3)
Hi
Can  z-uno be  used as a water meter on Fibaro Home Center 3.
Thank you
11 answers to this question
Ping me after my work trip
i have more than 4y running in HC2 and now in HC3 3 devices zuno
one of yes water meter
    Thank you
    Please let me know when you return and are available.
    I'm thinking to buy z-uno shield. I think with this version most is already ready to be used as i need it.
    8 hours ago, joaoartur said:
    Thank you
    Ok. Btw this shield already mounted in my backyard;)
    Hi
    I already manage to configure z-uno shield as a water meter using the example provided on the z-uno shield site.
    Neverless i changed the code in order to use only one water meter
    Questions:
    1) What  pins/channelnumber you used on the following code?
    2) Where you connect the water meter on the z-uno shield?
    Thank you
    @joaoartur
    Hi
    Thank for the information/link but since is my first time on this device i'm unable use it to answer the two questions i asked before.
    For example since you have already a working water meter solution using z-uno shield can you please sent me if possible a picture showing exactly where you connected your water meter on z-uno shield and what you changed on the below lines of code?
    Thank you
    Regards
    @joaoartur
    1st, I wouldn't unpack my old box with arduino zuno.
    more than - here is old verison fw for zune.
    2nd. well. I have take another one zune
    here is photo
    /monthly_2020_08/image.png.77c44af8e65b4116f9827192fdae8c07.png" />
    here is test sketch
    here is debug window
    so, it's works.
    but code is not compatibily with code what I developed 1.5y ago!
    Thank you
    My have different connections
    I will try to find how to do eventual changes on code and where to connect the water meter.
    If i cannot  i will try to buy  one equal to the one you sent on the image.
    You remember where you bought it?
    Thank you
    I am ukrainian... russia is nearby :(
    No problem i will do some searches.
    Thank you for your support ??
    @joaoartur
    /monthly_2020_08/image.png.020a315e526f6a2a36a161e3188eb78c.png" />
