jmconstans 0
when i change parameter 150 to 2 and 154 to 10 for example, Q1 is set to momentary with 1s ON. when I try to change with same value on Q2 (parameter 151 and 155) , Q2 is always set as standard mode.
And also if Q1 and Q2 are set in standard operation , lock enabled works well but if i change Q1 to auto OFF, lock doesn't works, curious because i want to avoid 2 outputs ON in same time and even if Q1 is auto OFF, Q1 is momentary ON and if Q2 is ON ... problems
is it a limitation ? a problem of configuration ? an evolution to make on this module ?
Best regards
Edited by jmconstans0 answers to this question
