Broadlink HUB 1.0
crypt lib adopted by @tinman
magic code for discovering via UDP by @tinman
v1.0 - 31/07/2020
* code re-written.
* button for generate child with broadlink devices
* if you have child device(s)  you can call
fibaro.call(1959"sendIRCommand", command)
without Ip Address. io directly
v2.0 - 04/08/2020
minor fixes
how to use:
where 1936 broadlink HUB
you brodlink device 192.168.1.39
26006800C0FA127213721471 BLABLA broadlink commabd
how to decode file command:
Edited by 10der
7 answers to this question
happy HC3 user ;-), congrats from HC2 user
    also you may convert file to LUA and use as bridge
    example attached
    /monthly_2020_07/image.png.ecc2a52ab15622b9a65b052e2ebbde87.png" />
    so, now you can call this QA with normal commands
    fibaro.call(1819"sendCommand""192.168.1.39""heat.auto.24")
    fibaro.call(1819"sendCommand""192.168.1.39""cool.auto.24")
    fibaro.call(1819"sendCommand""192.168.1.39""cool.high.24")
    VD powinno dzialac w HC2!
    I correct my statement:
    Happy owners of HC3, because you have it and you create now solutions for it. ;-)
    Updated to v.20
    so converting this fqa to lua would work on HC2?
    Tak
