I have created a QA that discovers all the devices on my home C-Bus network , mainly lighting.  After a few false starts it's correctly added about 200 child devices and it's working well.   However I have about 50 mistakenly created devices I would now like to remove.   If I click the delete (wastebin) icon on any of those children it warns me accompanied by a list of all the children, that it's going to have to delete every child device which was a surprise.
So I haven't done that and instead was considering using the api to delete a child. But I'm worried it might delete them all as well.  Why is this happening from the web UI and will delete via the api just delete the one specific device ?
I realise I can hide or disable the unwanted devices but I would prefer them gone totally.
I created a backup as a fallback but was a bit alarmed to see this....
/monthly_2020_08/image.png.522af6e603ae06ed3d6186129b6c3ba7.png" />
I have way more than 2 devices on my system not counting child devices. The scenes and rooms are correct
12 answers to this question
if you delete the main device if should be remove 100500 child devices
    .. sorry ? I miss the point of this reply.   I want to delete one child devices and it says it will delete them all within that parent. I am not deleting a parent device.
    If you delete the parent, all the childs, also the 50 mistakenly are deleted.
    Then let the parent create the childs again.
    Don’t forget to download the quickapp.
    Edited by SmartHomeEddy
    Ahh yes - I considered that but it took quite a bit to create them - lots of manual name edits for example - and I really didn't want to create a big deviceID gap either - so I guess the question is can I delete a single child device via the api ?
    Easiest way I suppose is to create another parent with just a few children and try it...
    Kevin
    Edited by xAPPO
    After this.
    self:initChildDevices({--[[something]]})
    try
    self:removeChildDevice(id)
    or
    api.delete("/plugins/removeChildDevice/" .. id)
    Edited by rangee
    Will it work with the API?
    26 minutes ago, rangee said:
    After this.
    try
    or
    The api.delete doesn’t update the self.childDevices list. That’s the role of self:re moveChildDevice. The only trick is if you have some mapping variable that you need to keep in sync. I assume that some of the plugins could be confused if their children were deleted without their knowledge....
    That doesnt matter
    just restart parent QA :)
    5 minutes ago, rangee said:
    That doesnt matter
    Well, I wouldn’t bet that it’s true for all QAs. In Fibaro’s example for childDevices they store the map in a quickAppVariable, and They read it back at restarts... If one forget to resync that to reality....
    Much better then to only rely on the childDevices list and store mapping data in the child devices themselves.
     yes. case by case.
    But  key point is that.
    ps. I store data in child device's information. So in my case, just do self:removeChildDevice  make sense.
      .. and indeed it isn't true of mine !   But I can of course remove the mapping as well.  I was just establishing it worked for a single child device.
    Why does the web UI 'delete' on a child device delete them all ? Is that a bug ?  It seems they've considered the result because they warn you and give you a list of the child devices so they intend, or know it will remove all
    I had the same Problem, a lot of virtual junk child devices added to a quick app device erroneously generated by a constructor code. Then I renamed that Child Devices "toDelete" in the device list manually, filtered them by name, and after rename I was able to delete them manually with the waste bin symbol, they were also removed from the device tree in the master device ....
