joaoartur 0
Hi
I installed a fibaro dimmer 2 with bypass 2.
I forced calibraton with bypass (parameter 13).
On the calibration process the lights dimmed perfectly.
After that i can only turn the lights on and off. When i try to dimmer for example to 50% as soon as i release the roller it goes immediatly to 100%.
If i use instead with the same lights dimmer 1 with bypass 2 everything works just fine.
What could be wrong with dimmer 2?
Thank you
