lua http problem with parameter
local body = "devices,device=Kitchen_ceiling status=0"
function InfluxDB()
        local http = net.HTTPClient({ timeout = 3000 })
        http:request("http://192.168.1.86:8086/write?db=ha7", {
        options = {
            data = {body},
            method = "POST",
            headers = {
                ["Content-Type"] = "application/json",
                ["Accept"] = "application/json",
        success = function(response)
            fibaro.debug("demo",response.status)
            fibaro.debug("demo",response.data)
        end,
        error = function(message)
        fibaro.debug("demo",message)
InfluxDB()
The above lua code is not working as expected on my hc3.
Influxdb keeps telling me "database is required"
This http request is working fine with Postman. ("http://192.168.1.86:8086/write?db=ha7" )
After doing several tests, I suspect the hc3 http implementation.
I think there might be a problem with parameters in the url.
So everything after ? is not being send or malformed.
Can anyone confirm this is a bug or otherwise tell me what I'm doing wrong ?
Edited by vinkenb
1st see my post with solution for influx
2nd do you know about urlencode function ?!@vinkenb
    urlencode function is definately the answer to my question.
    It's working fine now!
    Thanks for your help.
