Good morning,
even though I read the documentation and everything works with GET/POST/DELETE, I can't understand what I have to do to modify a room that exists (id=279); I always receive return code 400:
[DEBUG] 09:01:40: response.status 400
[DEBUG] 09:01:40: failed
[DEBUG] 09:01:40: response.data {"type": "ERROR", "reason": "id", "message": "no id"}
[DEBUG] 09:01:40: type ERROR
[DEBUG] 09:01:40: message no id
[DEBUG] 09:01:40: reason id
Here are the instructions:
--%% autostart
%% properties
%% globals
print('crearoom')
created = false
stanzaID = 0
stanzaid=279;
nameRoom="newstanza";
sectionIDRoom=219;
print('chiamataPUT')
date = os.date();
requestBody = {body = {name = nameRoom, sectionID=sectionIDRoom}}
httpClient = net.HTTPClient()
httpClient:request("
        options = {
           data = json.encode(requestBody),
           method = "PUT",
           headers = {
               ["Content-Type"] = "application/json",
               ["Accept"] = "application/json",
               ["Authorization"] = "Basic XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX",
       success = function(response)
          print('response.status '..response.status)
          if response.status ~= 200 and response.status ~= 201 then print("failed"); end
          created = true
          print('response.data '..response.data)
          results = json.decode(response.data)
          for k,v in pairs(results) do
           print(k, v)
           if k == "id" then
            stanzaID = v
            print ('stanzaID 1 '..stanzaID)
       end,
       error = function(message)
           print("error:", message)
Thanks in advance.
Lorenzo
ex
api.put('/scenes/49', {iconID=0})
      api.put("/globalVariables/"..i, {
        name       = i,
        value      = v.value,
        isEnum     = v.isEnum,
        enumValues = v.enumValue
notice HC2
    Thanks, the scene's working now.
    Wanting to do the same operation in CURL I get a return code = 200, but the data are not updated; where am I wrong?
    This is the string:
    curl -v -X PUT -d "{name="NunuCURL", sectionID=219}" -H "Content-Type: application/json" --url http://XXXXXXXX/api/rooms/279 --header "Authorization: Basic XXXXXXXXXXXXXXXXXX"
