centralSceneEvent
Hey Fibaro
for what puposes are you  check type of keyAttribute
Hey, listen up!?
test scene
  conditions = { {
      id = 1974,
      isTrigger = true,
      operator = "!=",
      property = "centralSceneEvent",
      type = "device",
      value = {}
  operator = "all"
test QA
-- magic cube
    self:updateProperty("centralSceneSupport",  {
        { keyAttributes = { "Flip90","Flip180","Slide","DoubleTap","Rotate""Shake" }, keyId = 1 },
        { keyAttributes = { "Flip90","Flip180","Slide","DoubleTap","Rotate""Shake" }, keyId = 2 },
        { keyAttributes = { "Flip90","Flip180","Slide","DoubleTap","Rotate""Shake" }, keyId = 3 },
        { keyAttributes = { "Flip90","Flip180","Slide","DoubleTap","Rotate""Shake" }, keyId = 4 },
        { keyAttributes = { "Flip90","Flip180","Slide","DoubleTap","Rotate""Shake" }, keyId = 5 },
        { keyAttributes = { "Flip90","Flip180","Slide","DoubleTap","Rotate""Shake" }, keyId = 6 },
function QuickApp:onTestButton()
  local modifier = "DoubleTap"
  -- local modifier = "Pressed"
  local data = {
    type =  "centralSceneEvent",
    source = self.id,
    data = { keyAttribute = modifier, keyId = 1 }
  api.post("/plugins/publishEvent", data)
NOTHING!
  local data = {
    source = self.id,
as expected
    @A.Socha also question why you drop user data?!
      local data = {
        source = self.id,
        data = { keyAttribute = modifier, keyId = 1, info = {aaa = 5, bbb = "aaaa", ccc= 3.123} }
    [19.08.2020] [18:16:50] [DEBUG] [SCENE85]: {"id":1974,"value":{"keyAttribute":"Pressed","keyId":1},"type":"device","property":"centralSceneEvent"}
    that will not work like you think, e.g. will not generate anything (that example should send something, because it is based on working KEyFob QA, but id does not, because of unknown trigger names, liek these you tried).
     Additionally i think remote control QAs are not properly working, when they just generic remote, however they works if one use known remote, e.g
    That part is responsible for what one see in Block Scenes, when names are known the proper BUI name (1x, 2x, hold, etc) will be displayed, when the name is unknown the string with centralscene...name will be displayed (just test both attched and you will understand what i mean)
    keyID 6 till 12 are normally not known for keyfob, i remember i saw them in HC3 sources, so added to my QA.
    Edited by tinman
    @tinman thnak you. ok drop it. here are in the back of beyond!.
    just trying port my code from Node-red to Hc3... but not destiny.
    node-red. zigbee
    Edited by 10der
