Walli Dimmer and Walli Switch interaction
Joystick
Hi all,
i managed to get a Walli dimmer and a -switch to control one light, sort of.
When I push the dimmer the Walli switch and the light is Switched on. Switching off the dimmer switches off the light but the Walli Switch stays on.
What I did was putting the devices in Ass.Group 2 in single, and grouped the devices in Advanced Configuration.
see also:
Is there something I am missing?
cheers
joystick
Edited by Joystick
Have you tried as described below?
  1. Install Walli Dimmer in box with load wires.
  2. Install Walli Switch in the second box (without the load)
  3. Change operating mode of Walli Switch to Single Switch Mode:
    • Quickly, three times click, then press and hold one of the buttons to enter the menu.
    • Release button when the device glows white, then click again to confirm.
    • Ring should blink white once.
  4. Add devices to the Home Center.
  5. Change Walli Switch parameter 20 to 2.
  6. Set association in in Walli Switch to Walli Dimmer in 3rd association group:
    • Go to the device settings of Walli Switch by clicking the wrench icon,
    • Go to Advanced tab, find Associations section and click Setting Association button,
    • Find 3rd Association Group in Endpoint 0 and click it,
    • Find Walli Switch on the list and check it in the S column,
    • Save.
  7. Repeat the previous step to set association in 1st Walli Dimmer to Walli Switch in 2nd association group.
  8. Group Walli Dimmer with Walli Switch:
    • Go to the device settings of Walli Dimmer by clicking the wrench icon,
    • In Device grouping section click Walli Switch,
    • Save.
