Michel88 0
I have several problems to get my HUE lights working white my Fibaro HC2. I have made a scene for my bathroom just to turn on and off the light in combination white a motion sensor. This is working fine but the light is always changing back to the warm color after about 24 hours. So i like to set the color by a LUA command. I used the debug function for the settings (see below)
%% properties
%% events
%% globals
fibaro:debug(fibaro:getValue(162, "ui.brightness.value"))
fibaro:debug(fibaro:getValue(162, "ui.saturation.value"))
fibaro:debug(fibaro:getValue(162, "ui.hue.value"))
If i change the Brightness on the HUE app the value changed. But the saturation and HUE value doesn't change at all.
Whats the problem? is it a error of the Hue bridge (square one) or anything else???
This Youtube example looks oke to me:
All you input is welcome and of course i can provite more information if necessary.
Thank you in advance.
Michel
