Twannie 33
Hi all,
I am sure many asked this before but I wonder what the current status with the HC3 is.
I own a HC2, have 90+ physical modules and 135+ scenes, almost all in LUA and the system is running quite fine.
I wonder how stable the HC3 is and what is still not possible what IS possible with the HC2
I use plugins like harmony, HUE etc... are they also available for the HC3 and more- important, working?
I also use quite some VD's like Weather Station, Netatmo (from the master @Sankotronic) and created/adapted VD's myself to get data from other devices through HTTP using LUA.
I really like the HC2 but the web-interface could be a bit better, easier to navigate (However, I DO like the looks of the dark interface)
Is this currently all possible in the HC3 and how stable is the system in general nowadays and is the step-up really a step forward?
I am having doubts as support could be better with Fibaro (still not everything fixed and supported in the HC2) so I do not expect things to be much different with the HC3....
The thing is, there are no real other contenders to use as home controller (except maybe Domoticz/HA)
6 answers to this question
