Aeotec WallMote Quad
kenneth.horn@gmail.com
19 answers to this question
16 scene with the 4 buttons. Then you must use some logic to arrange the buttons, just so you can remember which button to push?
no problem for me,
example:
left button up -> left window open
left button down -? left window open
right button up -> right window open
etc etc
58 minutes ago, SmartHomeEddy said:
I received a Wallmote. Now think what to do with it ?
you can stick it to the wall?
So this integrates and supports swipe up/down functionality?
Is there also a top/bottom row row swipe left/right function too ?
Trying  to understand how you trigger the 16 different scenes, ?
4 press
4 double press
4 swipe up/down
?? + 4 more somehow ?  Is this ‘hold’ for 4 more ?
Edited by xAPPO
Yes, it also registeres hold
/monthly_2020_10/BBF36E58-ED3E-4C27-ABF7-2F40274CC5D1.jpeg.8d0c596048647ded8d9a97d1177545c6.jpeg" />
What about this?
Edited by SmartHomeEddy
It doesn't register double tap it seems .. not sure if it's meant to, only just got mine today
Edited by xAPPO
hello :)
Any one having developped a scene or QA for this and to leverage all potentials?
br
W dniu 5.09.2020 o 11:41, [email protected] napisał:
Hello.
Im having trubble with my Aeotec WallMote Quad
HC3 is reporting the device is not configured, anyone know how to fix this?
facing the same problem (Wall Mote v2.3 and HC2 4.620) - Wallmote is not configured, tried adding it several times but no result...
Any hints?
br
  • -1
@SmartHomeEddy
Yes, it's magnetic,
you stick the base to a wall. and on that base you click (magnetic) the rest
I use (and used) a lot of wall controllers and this one is at the moment the best.
