10der 832
Hi guys!
situation. You create a nice QA,.
your QA for example has 5 settings in QA variables
unfortunately all 5 vars is sensitive information (password etc)
you press export QA and share in forum / marketplace.
finally your sensitive informatin shared successfully! :)
OK!
you clear all sensitive info from QA vars and export.
now you should restore all settiong after export!
if you have a some changes in your code you always should clear / export / refill.
IMHO it's not right. any suggestions?
@A.Socha You promised about [password] field in Quick App Var. This value should not exports!
