I am creating a QA to list doors that are still open when I switch on the alarm. And I want to display the doors that are still open on the QA interface, one below the other.
I have been trying to insert a return character in the text to be inserted in the label with self:updateView() in order to achieve a nice list of doors. But whatever I try to insert in the string to be displayed (\n, \r, string.char(13), <br \> etc) the separate lines remain on one line in the label.
What is the correct procedure to insert a CR in this case? Or is there an alternative like dynamically adding labels to the QA?
Here is an example from @tinman, in this case to show multiple lines of rain forecast in one label.
The view in the "EDIT" mode is different from the view from the dashboard and mobile app.
    Thanks!
    This was my problem. I didn't check it in the mobile app, just in the editor....
    You can also check it in the dashboard and preview
    Thanks again!
