QA: Presence simulation
subj!
configuring:
local rooms = {
    "Section1/roomName1",
    "Section1/roomName3",
    "Section2/roomName7",
    "Section2/roomName5",
    "Section1/roomName13"
-- just sectionName slash roomName
-- "GroundFloor/WC"
local exclusion = {}
-- You can provide here DeviceId's what you wnat to exclude from simulation
local timestr = "$Sunset..23:00"
local timestr = "19:00..23:00"
just period when simulator works
startTime..endTime
You can start and stop emulator manuall via button or via scene
enabled / disabled action you can configure via triggering in scene
- alarm system
- switching profiles to AWAY
- etc
  • Thanks 2
10 answers to this question
Hi @10der,
Thanks for that! I uploaded the QA but I get the following error after enabling it:
It relates to the checkOff() line, part of the local function doSimulate(rndlight) function.  I have not changed anything besides the sections/rooms definitions on top.
Furthermore, and probably related to, is that I cannot disable the QA - the buttons don't seem to change its state.
Thanks for your time!
for me the same problem:[01.12.2021] [21:54:01] [ERROR] [QUICKAPP499]: main.lua:64: attempt to call a nil value (global 'checkOff')
Yes,
local function doSimulate(rndlight) calls local function checkOff() that is declared afterwards.
Open the QA and change
to
I will not guarantee that it works but it will at least fix the missing checkOff function
The QA will not enable/disable as it isn't checking the enabled state when it starts up
On 12/1/2021 at 10:08 PM, jgab said:
Yes,
to
I changed the above and the below lines for room + timestr, but still got an error.
Debug:
26.01.2022] [12:17:00] [DEBUG] [QUICKAPP96]: onInit[26.01.2022] [12:17:00] [DEBUG] [QUICKAPP96]: Begane grond/Woonkamer [40][26.01.2022] [12:17:00] [DEBUG] [QUICKAPP96]: the section of room name Section1/roomName3 not found[26.01.2022] [12:17:00] [DEBUG] [QUICKAPP96]: the section of room name Section2/roomName7 not found[26.01.2022] [12:17:00] [DEBUG] [QUICKAPP96]: the section of room name Section2/roomName5 not found[26.01.2022] [12:17:00] [DEBUG] [QUICKAPP96]: the section of room name Section1/roomName13 not found[26.01.2022] [12:17:00] [ERROR] [QUICKAPP96]: QuickApp crashed[26.01.2022] [12:17:00] [ERROR] [QUICKAPP96]: main.lua:172: attempt to compare nil with number
Changed rooms & timestr:
local rooms = {
    "Begane grond/Woonkamer",
local timestr = "$12:00..13:00"
Edited by pnutp0wer
Just imported the QA again, I changed the sections and it was working.
When I changed the timestr to "12:45..14:00" the QA crashed with the same error as above. Am I doing this wrong? Do you need to change other elements too?
    so, QA is started
    and will use 628,1990,2201,2211
    devices as Presence simulation
    anyone got this QA working? I don't, it does start, gives me the configured room and light id's, but nothing seems to happen after that in the timeslot.
    Description is very limited and unclear.
    This code is a QuickApp for the Fibaro Home Center 3 (HC3). Its purpose is to simulate human presence by randomly turning lights on and off in specific rooms during a defined time window.
    Here is a breakdown of how the script works:
    1. Configuration (The "Who" and "When")
    At the top of the script, you define your settings:
    • rooms: A list of rooms to include in the simulation (format: "Section/RoomName"). Currently, only "Upstairs/Office" is active.
    • exclusion: A list where you can put specific Device IDs you want the script to ignore (e.g., a nightlight you never want to trigger).
    • timestr: The time window. In your code, it is set to 12:45 to 14:00. This function is quite advanced; it can also handle keywords like $Sunset or $Sunrise.
    2. Initialization (initRooms)
    When the QuickApp starts (onInit), it performs a "discovery" phase:
    1. It scans your entire HC3 for sections and rooms.
    2. It filters for devices that are enabled, visible, and specifically marked with the property isLight = true.
    3. It groups these light IDs into the fake_devices table.
      • Based on your logs, it found 4 lights in the Office: [628, 1990, 2201, 2211].
    3. The Logic Loop (check)
    The script runs a check every minute (setInterval). Here is the logic it follows:
    Step A: Time Validation
    The between(timestr) function checks if the current time is within the allowed window.
    • If YES: It proceeds with the simulation.
    • If NO: It calls allOff() to ensure all lights used in the simulation are turned off once the window expires.
    Step B: Turning Lights ON (doSimulate)
    If the simulation is active:
    1. It picks a room at random from your list.
    2. It checks the lights in that room. If a light is currently OFF, it turns it ON.
    Step 😄 Turning Lights OFF (checkOff)
    This is what makes the simulation look "real":
    • The script doesn't just turn lights on; it checks how long they have been on.
    • It generates a random number between 1 and 30 minutes. If a light has been on longer than that random duration, the script turns it OFF.
    4. Strengths and Weaknesses
    Strengths Weaknesses / To Watch
    Realistic Behavior: Lights don't stay on forever; they turn off after a random duration (1–30 mins). Fixed Time Window: Your current setting (12:45) is mid-day. For real security, you’d usually use $Sunset..23:00.
    Automatic Discovery: It finds your lights automatically based on the room name; no need to manually find IDs. One Room at a Time: In each 1-minute cycle, it only picks one room to "activate," which might be slow if you have 10 rooms.
    Section Support: Great for large houses with many sections. Emulator Dependency: The very first lines are for a developer's local emulator; they aren't needed for the HC3 itself.
    How to adjust it
    1. Change the Schedule: Edit local timestr = "12:45..14:00" to something like local timestr = "$Evening..23:30" (Sunset until 11:30 PM).
    2. Add More Rooms: Remove the dashes (--) in the rooms list or add your own following the "Section/Room" format.
    3. Manual Control: The script includes functions for buttons (onBtnOn / onBtnOff). You should see an "Enabled" label on your QuickApp interface to tell you if the simulation is currently armed.
    (Gemini 3)
    Edited by Julien6
    @Julien6 are you an AI bot or spam account reacting on a post from January 2022?
    Yes, from Openclaw framwork.
    Lol, I'm joking. I'm a human but I recognise I used Gemini 3
