galileo634
Hi. I'm new with Fibaro. Wich weather station you recommend that integrates with the system and allows use in scenes, etc?? I've a HCL. Thanks
8 hours ago, Bodyart said:
Every device that can communicate through http(s) with an API can be integrated with Fibaro :-D
Tempest Weather System working via BT only (according to description)
Edited by 10der
i dont know if it works in HCL. but in HC2 i use Netatmo weather station works great.
what ever u do dont get involved with popp.
succes.
greetings TSN
2y as I used GOAP weather meteo station
but now this device obsolete:(
10 hours ago, TSN2 said:
Netatmo
Uses clouds. And when clouds on the maintains or you have a troubles with connection you can’t work with meteo station at all
/monthly_2020_09/image.png.ba66048dfa93fcf1f1e31f0476469865.png" />
2 external sensors with Temp + Hum
outdoors - wind speed + win dir + temp
"toilet bowl" - rain metter
last has some nuances... you can't run somthing when rain stated cuz device start calicate and send the rain signal after internal "teeter-totter" make from up to down
 I was also searching for this one but i found it's EOL.
Edited by Flash
44 minutes ago, Flash said:
End of Life. no longer in production
another proposition to bough any 443/wifi China meteostation
like
Thanks for mentioning, did  consider this option. Still not decided yet. Because still a newbie creating QA and a steep learning curve ahaed.
@Bodyart was working on a QA for(still hoping he is ?)
So far as I know still not available in Europe, but could be completely wrong.
I'm not in a hurry, just having fun learning trying and so on.
weatherflow very cool!
but as i know can buy only in USA.
try to google MISOL brand
Hi @Flash,
i have already posted one QA for weatherflow (beta)
and @afendikov has also posted one QA which also provides UDP connection.
  • Thanks 2
Hi @Bodyart
 I saw you're posting.
Maybe I confused by you're remark  "Your QA variable stationNo should be set to 1 for the first WeatherFlow station,"
Because I own no Weatherflow station. So i didn't try it. Don't need the UDP connection.
Also my opinion, hopefully it will be available in europe.
Afaik, there will be versions with European and Australian frequencies as soon the certification is ready :-D
Some people may have more than one station for example 1 in house and 1 in cabin or similar.
I have the "Original" WeatherFlow station and awaiting Tempest to be delivered soon (Indiegogo campain) :-D
Edited by Bodyart
Jippie, maybe something for a group buy.
Nice , lucky you. ?
 Oke but I got no station, so will you're QA work??
WeatherFlow don't do a group discount, but maybe some postage cost can be saved.
My QA reads the data from WeatherFlow station only, but there are other QA's reading weather data from the net.
tru, but im using netatmo for about 1 year now, and i had no isseus yet
    Tempest Weather System works with Fibaro??
    Thanks. I’m a newbie here. I’m trying to understand scenes, etc.
  • On 9/18/2020 at 3:26 AM, Bodyart said:
    How can I integrate the Tenpest system via an API with Fibaro?
