block scene - groups - how to create
Hi
how can I create a group to use in a block scene
When I add devices->group the dropdown is empty/I cannot click it.
I want to group all lights to be able to set brightness at night to 1% if a light is turned on.
7 answers to this question
I you are on a HC3, then it doesn't work anymore, it is a bug. It will be solved in the next update. I think that update will come real soon no, if I look at the time between the different updates.
Until then, use have to use the single device option.
It is fixed in 5.041+
You will see beta soon or may wait for 5.050 GA is that is not that much important
@A.Socha
And when is 5.050 expected ?
This month
17 minutes ago, A.Socha said:
This month
Yesss, finaly the master/slave gateway connections :)
Nope :( not in this version. It is on internal tests. Probably it going to be 5.060
    Sounds like it's close. I am still on 5.040.37
    Looking forward to the update.
