iS21 2
I use some scenes do command my Hue lights and today, while trying to make some new complex scenes, I discovered that the http commands are sent at the end of the scene, and all together.
Let me explain:
This works perfectly.
But now, if I add "sleep(5000)" at the end, the command is triggered only after the sleep.
In this case, the device turns on and 5 seconds later it turns off.
But not for the http requests.
For example, with the full codes here I would have the lights command only after the device 1 is turned off, 5 seconds later.
The issue for this is because I want to send a command to the light with a long transition time, sleep and then send a new command to the same light.
Obviously when they are fired at the end together only one works.
Also it's not only about lights it does that with all webpages.
I know this example code is usually for QuickApps... so maybe I miss something there?
