HC3 issue
Two nights ago i received over 100 mesages about the battery low level at a door sensor from my home.
After i arrive home i login into the web interface and at that door sensor i unchek the notification for the battery down but the emails still arrive with this warning.
From the web interface i did a reboot the HC3.
After the reboot the HC3 made himself a autorepair or something like that, and after made himself an auto backup then didn't start and stuck on the rebooting.
Ive pluged out and in from the power after 20 minutes of waiting and now i only see few fibaro devices and most of the devices that was installed are gone. Also can't see any device in the mobile app.
Made a ticket yesterday morning but didn't receive an answer yet.
Anyone know were the autobackup was made? Because in web interface i cant fiind any backup from that night.
5 answers to this question
the same here. but my fairy tale ending with re-sinstalling old backup.
but! you maybe lucky.
1) rebooot to recover mode
2) you probably on "side B"
3) switch to "side A"
4) after rebooting you should see all OK.
    Thanks for the answer, but can you tell me how to switch to "side A" ? :) thanks
    reboot HC in recover mode.
    you shoud see boot.
    can you make a screenshort here from RECOVER UI?
    you shoud see boot.
    Ive done it. it works now. Problem solved! Thank You
    welcome
