LUA. Telegram. Change HC2 to HC3. Where am I going wrong?
Obs: Sorry for possible errors ... I used the google translator.
Hello.
I migrated from HC2 to HC3. At HC2 I had a generic scene that was called by several others to send me a message on the telegram.
Example: Someone touched the campaign, I received a message on Telegram: "The campaign has been activated". The door was opened, I received a message "the door was opened".
It used a global variable in which the main scene determined the variable telegram and, after that, the generic scene that sent the message to the telegram was called.
However, with HC3, this scene stopped working.
I made some changes to the LUA code, but I can't get the message on the telegram.
Example changes: I changed "fibaro: getGlobalValue (" Telegram ")" to "fibaro.getGlobalVariable (" Telegram ")"
The error message I get is:
[DEBUG] [SCENE54]: 400
[DEBUG] [SCENE54]: {"ok": false, "error_code": 400, "description": "Bad Request: message text is empty"}
I put one more message in this code to see the value of the variable Telegram and url, and both are not reset.
fibaro.debug("URL é", url)
fibaro.debug("MSG é", msg)
From the commands above I can verify that the variables are with the values I want.
Please, could someone guide me where I was missing the LUA code below? Thank you.
14 answers to this question
so. as I haven't any plans to publich this QA - QA prrovided as-is :)
how to send message
send pic from url.
for example
(c) Fibaro
You do not need that’s at all
no global etc
just ping me for 2h
I’ll provide here QA for sending messages and pictures via telegram
good Morning
I would be interested in that too!
Would you be so nice and would you send that to me too?
I've only created one variant with PushOver.
If you are interested I will take the post.
However, this can only be used to send texts.
Greetings Frank
    Hello ....@10der and @FBerges , initially, I apologize for any errors in the writing. I used the google translator.
    @10der ,  your code is Fantastic!!! Thanks for your suggestions and the code.
    I made the adaptation to mine and it worked perfectly.
    This will solve my "emergency" so as not to miss my apartment's security messages (door open, etc.), however, with its complete code, I will make some changes over time to implement it in order to increase productivity HC3.
    Thanks again.
    @FBerges , this code suggested by @10der worked perfectly....
    If you still have any difficulties, please post here what it would be. I don't understand much, almost nothing in fact, but we can look together or another colleague can help.
    Hugs
    how to send message
    send pic from url.
    for example
    (c) Fibaro
    salut
    à quoi correspond  :   1818    et    11111111
    what is  :  :   1818    et    11111111
    et dans ton code je voie BOT-KEY mai je ne vois pas le chat_id
    and in your code I see   BOT-KEY     may i don't see the     chat_id
    Edited by 971jmd
    J'ai trouvé
    I found
    fibaro . call ( 1818 , "sendMessage" , "Hello HC3" , 11111111 )
    1818  =  ID  Quick App
    et
    11111111 =   chat_id
    merci
    thank you ?
    Pour l'envoie de l'image j'ai une erreur.
    To send the image I have an error.
    scena
    @10der. Thanks for this Telegram QA, excellent job done!!
    Is it possible to add the chat id in the code somewhere so in the message it will  "hide" the chat-id?
    Thanks in advance,
    //Sjakie
    no global etc
    just ping me for 2h
    Just wondering if the QA file is available for Telegram in Fibaro.
    asking Fibaro :)
    @AlecPickles, if you paste what @10der has as code in a QA you have it.
    //Sjakie
    nice idea. via vars. ok wil do
    On 10/5/2020 at 8:51 AM, 10der said:
    scena
    Just want to understand.. can this solution be used for controlling HC3 devices outside the HC3 LAN ? As a solution for this
