HC3 - start scene if temp is a bow 9 degrees
Hello
I'm new to making scenes in HC3, -just bear with me.
Thought to start with some simple things like Trigger and Conditioning.
Have a source I want to get a message if the temperature is above 9 degrees
But the scene is running even though the temperature is below 9 degrees (see picture)
Have tried to read on how to do. Feels like it's a simple thing I am missing
I have also the same problem with freezer (not unexpected but  i guess ) :D
But i would like to have that on -18 in stead
4 answers to this question
If I understand it correctly you keeps getting notifications every time the temperature changes when it’s already above/ below 9°
Create a variable with 2 values.
Create a scene that changes the value when the temperature is below and above 9°.
Then use the value of this variable as a trigger for you scene
Edited by kevin
    Thanks Kevin for your answer
    I do not know, if i got the scene running if it is above 9, but that´s the thing :)
    If it is below +9° then do not run this scene
    if it is abow +9° the run this scene
    I thought "operator" and "value" was a condition of running this scene
    I have done like this for the moment. but it does not feel right
    local temp = fibaro.getValue(77,"value")
    if temp >= (9and temp <= (12then  "something"  end
    @Apax from prinstcreen i see that you got only part
    If (id 77) < 9 then start (action block) so your scene will start when temperature is below 9 and from what you writing it work how it schould
    if you want to run when is higher then 9 change operator from < on >
    if you will use -18 then it will looks
    If (id 77) < -18 then start (action block) (scene will start when is colder then -18.1
    and please change fibaro.sleep you using it in wrong way
    more info about scenes and fibaro sleep you will find here
    Yes , that´s it .-of course
