So ..... i found a great program in marketplace, but, cant load it into HC3 ... wrong type. Yes, i know that VDs became Quick Apps and are someway incompatible but would be good to get the base code anyway to start from. Any good way to change the filetype do HC3 can read it at least? Is this a silly idea?
@Relaxandbecool
you have many options:
1) ask the original author whether VD can port (rewrite) to QA
2) ask the community if they can do it
3) start studying the VD principle, learn LUA for both versions (VD and QA) and rewrite it yourself
After all, your contribution is very vague. If you write more, you may be surprised that someone in the community has already solved it and will provide you with a solution or at least help.
