Update 5.050 do NOT work, dont update!!!!
Yes - The same here. Restarted/booted again and now it is up and running. Regards, Jacob
All is ok ! super fast congrats ! cool ?
On 10/9/2020 at 8:59 AM, greg77 said:
I also warn against updating if someone has a "NICE ROBUS" gate, after pressing the remote control, the system crashes !!
Hi Greg,
I am thinking of getting the Roller Shutter 3 module to install it inside my Nice Robus motor. Can you offer any advice on it? My Nice Robus motor is about 13 years old so I am not sure if it is even compatible. I want to pair it with a Homee z-wave cube.
can you perhaps share a picture of how you have it wired up? From your post I take I shouldn’t update the firmware which I believe isn’t possible without the fibaro  homecentre anyway ?
thanks
Edited by rikscha
W dniu 20.10.2020 o 08:47, rikscha napisał:
Hi Greg,
thanks
Welcome.
If you have only the motor, Roller Shutter 3 will be a good solution, provided that the motor has 3 zero wires and the direction to the right and left, I have the motor with the controller and I used Single Relay Switch for control - it works fine.
