Bartagnan 0
Hi, i am trying to add a parameter for my neo coolcam motion sensor to switch off the red led. According to the documentation this should be parameter 10 and it should be set to 0. The issue is that when I add the parameter, it does not stick. The description field stays empty no matter what I try. The device does adopt the new setting after a wake up, but the led keeps blinking when motion is detected.
6 answers to this question
