HC3 RGBW LUA get value (FGRGBW441M)
Apax
Hi all!
Trying to read value from my RGBW
It works if i Set value via SetColor command via an LUA scene(like below) , but if i use physical buttons connected to the module and change color that way, I can not read what color is set.
example I am using this code and looping it
then I go to my buttons and push them , the only thing that changing is Value
i=0
fibaro.call(112"setColor""0""0""0""0")-- clear start
fibaro.call(112"setValue""0")--clearstart
while i <=30 do --setting a loop for trying
i=i+1
fibaro.sleep(2000)
fibaro.debug("Garage""Value : " ..fibaro.getValue(112"value"))
fibaro.debug("Garage""lastc : " ..fibaro.getValue(112"lastColorSet"))
The module seems to work well and change the color like i set it to
It has to be a way to read what color the device has even if it set by module input 1-4 ?
i can ad that this worked in HC2 :)
Edited by Apax
36 minutes ago, Apax said:
Hi all!
You could try
fibaro.getValue(id, "color")
  • role = output/input (or RGBW lights) solved the problem :)
