Mark Manning 1
I couldn't see a separate forum for the Double Smart Module FGS-224, but I understand that it replaces the FGS-223?
I have connected the device to a simple test circuit with a 230v feed and a single lamp - the same test circuit I am using to test, adopt and pre-configure my Dimmers without issue.
I have connected the live feed to both the L and IN terminal and the neutral feed to both the N terminal and the light, with a switched live from the Q1 terminal to the light. There is no physical switch.
The module switches on, is adopted into the controller and the controller reports that the outputs are on/off with a 'transfer OK' message when I switch them, but nothing happens.
All of the parameters are default at the moment, but I can't see anything in there I should need to change to get this working. What am I missing?
4 answers to this question
