HC3 - How autostart the scene after restart HC3
6 answers to this question
Lua scene (
On 10/24/2020 at 6:15 AM, jgab said:
Lua scene (
For EV4 i expected this to be something like this -  but its not.
I also tried to add se-start in the self:enableTriggerType
whats the magic ? ?
Edited by ChristianSogaard
p
whats the magic ? ?
No, in fact, the se-start event is not supported yet by the ER4. I will have a look tomorrow and post an update.
It will probably look something like
Thank you Jan. This is my last Scene. When this is moved - everything is in EV4
My next goal is the the to finalize the ALARM part
Actually, while you wait for me to find out how to implement it properly you can fake it in a way that is hard to tell from the real thing.
Inside main() add this line:
It will, when ER4 starts up, check if uptime is less then 30s and in that case post a #se-start event.
You can catch it with a rule like
If I can't find out the trigger (it doesn't seem like it is posted on /refreshStates) I will do something similar like the first line but builtin-in into the ER4 startup code.
Damm - you are Brilliant??
Will test right away - This is turning ON Matrix switches where DIMMER is disabled because they are used for Children Of Hue
P
