QA: simple remote for LG TV Web OS
/monthly_2020_10/image.png.b83be9cf70958d188d1bd0d3f1aee3c5.png" />image.png.b50fa0de4658927802b2a85027944be7.png
PS:for force pair please set key field as "-"
PSS: QA can't polling your TV, cuz I have a some issues with HC3 and too much open sockets. so if your TV was OFF and now ON just click CONNECT buitton for restore connection
PSSS: thinking about inheritance from fibaro.MediaPlayer but not sure....
Edited by 10der
  • Thanks 3
8 answers to this question
Thank you very much for the contribution, I have loaded it in my HC3 5.050.13 and it loads correctly. I configure the IP of my LG and put "-" in clientKey, but I press the connect button and it does nothing. I only get the message "action has been called" but without any results on TV.
Any ideas?
    6 hours ago, Juanjo said:
    Any ideas?
    No. But if you can see logs....
    It was a good idea to see the logs, as I recently migrated from the HC2 to the HC3 I did not realize it.
    The bad thing is that it gives me an error that I think is typical of ClickAPP:
    [03.11.2020] [18:30:54] [TRACE] [QUICKAPP215]: UIEvent: {"elementName":"button1","values":[],"deviceId":215,"eventType":"onReleased"}
    [03.11.2020] [18:30:54] [WARNING] [QUICKAPP215]: Class does not have uibutton1OnReleased function defined - action ignored
    do you understand what it means?
    Is there also a Virtual Device for HC2 ?
    Hello 10der,
    The MUTE button does not work. All other buttons work.
    I have an LG TV with webOS 5, model 2020.
    hi, I take 10der@'s qa and I've modified it.
    now I can work with volume, mute, toast, turnOn, turnOff etc...
    I remove CONNECT button cause it's automatic with turnOn function,
    but I not able to use buttons... (arrows, home, back, enter) any ideas?
