Juanjo 1
I am trying to gradually migrate my scenes in LUA HC2 to LUA HC3 and I am having some doubts/problems:
How I can make a scene that always is running, for example, this infinity loop that checks if the door is open:
HC2:
if (fibaro:countScenes() > 2) then
fibaro:abort()
fibaro:debug ('There is a other scene running')
while true do
--Check door open
if
( tonumber(fibaro:getValue(125, "value")) > 0 )
then
fibaro:call(234), "sendPush", "Door open");
fibaro:sleep(15*60000) --repeat each 15 minutes
HC3 (propose with errors):
Condition:
conditions = {
type = "se-start",
property = "start",
operator = "==",
value = true,
isTrigger = true
operator = "all",
Action:
while true do
--Check door open
if
( tonumber(fibaro:get(125, "value")) > 0 )
then
fibaro.alert('push', {[1] = 234, }, 'Door open')
It gives me this error:[03.11.2020] [21:43:29] [ERROR] [SCENE103]: (load):2: Assertion failed: Expected number
any idea where the problem is?
Thanks!
7 answers to this question
