While working from home for eight months now I had the need to toggle a light or run a scene from my Windows 10 laptop. After some Google I didn't find an app so I decided to learn basic C# and create a Windows tray application myself.
The application loads your configured rooms, devices and scenes from your HC2/HC3 and puts them in a menu in the system tray. Now you can run a scene or toggle a light switch without reaching for a wall switch or your phone. ?
The program looks like this:
/monthly_2020_11/Image002.png.4945d8e9f4b3ffcec10e57f395b1365e.png" />
I Iearn and get a lot from the Fibaro community, therefore I made the code open source on
You can
the application from the
. You only need the .exe file.
I don't own a HC3. If it also works on the HC3 please inform me. Than I add it to the
Edited by Joep
Added support for HC3
  • Thanks 4
Hi Joep @Joep,
it doesn't work with HC3.
/monthly_2020_11/afbeelding.png.fc813b9b68436029d2de98cc4a136633.png" />
In my case it doesn't work with HC2 either :-(
Here's the full debug:
    6 minutes ago, Bodyart said:
    Hi Joep @Joep,
     Thank you for testing!
    To get it working I need some JSON files from the API.
    Please send me a PM with your mail or WhatsApp and I can try to make it HC3 compatible the next couple of days.
    Are the login credentials correct? I need to program more error handling I think. But wrong credentials throw an exception.
    I fixed the error @bodyart got. This was due a large devices API reply. In C# the standard maximum JSON file size for JSON is 4 MB. Fibaro puts its Virtual Device code into the devices JSON reply. For big Fibaro configurations the loaded JSON is sometimes > 10 MB. Unfortunately you cannot filter out real devices only with the API request so I set the max JSON file size to Operating System maximum. With my test JSON I got from @bodyart I got it working on my system, so I
    I added support for the HC3 to my Windows 10 tray app.
    You can download the update from my GitHub releases page:
    Thanks to @Bodyart for testing!
    • Thanks 2
    • Joep changed the title to Created a Windows 10 app for Fibaro Home Center 2 AND 3
    Thank You. It works with my HC3.
