Showing results for tags 'homecenter 3'.
I have a Dimmer 2 with security level S0 and tried to connect Walli Controller by the book and with the code I got security level S2 Authenticated and leaving it blank or 000000 security level was set to None. When associate the two devices it complain on different security levels. When Adding Walli Controller as described below it gets added with security level S0. Add device Zwave Button Advanced, uncheck ‘Add in S2 Security mode if device supports it’ Start Device will be added in security level S0 Walli Controller Tab Advanced, Walli configuration Operator mode: Dimmer/Roller Shutter Controller Tab Associations Endpoint 0, Group 6 Multidevice, Choice your ‘Dimmer 2’ devices.
- 2 replies
- homecenter 3
- dimmer 2
Hi, I am evaluating using Fibaro Intercom as a main Door Bell. Looking for your thoughts and experience in the pros and cons of Fibaro Intercom in comparison to other IP SIP Doorbells. Mainly, I am looking to understand the advantages of using Fibaro Intercom with Fibaro Home Center 3. Can I for example correlate scenes with the Door Bell? What are additional features that I would get if I use the Fibaro Intercom that I would not get if I use other brands? If anyone is currently using the device, what are your thoughts? How is your setup?
- 1 reply
- intercom
- intercom voip doorbell
(and 3 more)
Hi, I use Homecenter 3 (software version 5.130.45) for 1 year now, with about 45 Fibaro Z-wave devices / HUE lamps. Working fine. Last i purchase the MCOHOME 9 in 1 multisensor A8-9. Added to homecenter. Like this picture: From the 9 sensors, 8 are working in homecenter (see picture) but CO2 doesn't. On the multisenser itself CO2 is working (see picture): Someone familiar with this problem?
Problem with the interaction of Heat Controller + Motion sensor
Hamburg2021 posted a question in Heat Controller
Hello all I am new to Fibaro - unfortunately I have not found anything in the forum on this topic. Goal: In a room with two heaters to work together through a leading room thermostat. But I have the feeling that even though the room controller for temperatur is set (in my case the motion sensor) the temperature is only used by the Heat Controller thermostat. Have I set something incorrectly? Components: Home Center 3 2xHeat Controller 1x Motion Sensor What I have done: Defined a new room Set the motion sensor as the main temperature sensor for the room the 3 devices are connected: 2xHeat Controller 1x Motion Sensor Created a new zone with a schedule Problem: The set temperature is NEVER reached at the motion sensor - even though it should be the leading sensor?! What am I doing wrong- 1 reply
- motionsensor
- heat controller
While working from home for eight months now I had the need to toggle a light or run a scene from my Windows 10 laptop. After some Google I didn't find an app so I decided to learn basic C# and create a Windows tray application myself. The application loads your configured rooms, devices and scenes from your HC2/HC3 and puts them in a menu in the system tray. Now you can run a scene or toggle a light switch without reaching for a wall switch or your phone. ? The program looks like this: I Iearn and get a lot from the Fibaro community, therefore I made the code open source on GitHub. You can download the application from the releases page. You only need the .exe file. I don't own a HC3. If it also works on the HC3 please inform me. Than I add it to the documentation.
Converting Block scene with interactive push into Lua uses `api.post("/mobile/push"` call. Yet there's no documentation for this endpoint in Swagger. Anybody happens to know more about it? Options? I can partly reverse it from what's possible in Block scene, but I suppose there's more. HC3 with 5.040.
Hi, is there a way to export (for backup purposes) scenes? All scenes or just Lua scenes would be enough for me.
