Showing results for tags 'walli controller'.
Found 6 results
  1. hi, i had to installed and used about 65 Walli controller in the same system to replace an old SCS (wired) Legrand system which had some trouble and couldn't be updated because of non compatibilities of the old devices with the new SCS controller, so i choose to move all the installation to zwave . All the switch button were on the SCS bus, so i couldn't get the N/L (230v) on the plug in the wall, the only solution i found is to replace with walli controller wired with 24v DC, using the old physical installation to deliver the 24DC on each plot. At this step i have 65 Walli controller wired on 24v DC to manage all the light and blind (BSO). All the Light and BSO were wired grouped in a single board on the underground technical place. I have choosen FGS223 to manager the Light, FGD212 for dimming light and FGR224 to manage the BSO. So my config is : switch on each room (65 walli controller), active device on a single room (45 FGS223/FGR224 and 5 FGD212) Because of a lot of multi use of each button, this new system need to use colored ring to have the status of the right light, green when ON, white when OFF. - 1rst : walli controller have no logical endpoint to read the returned state of the Light or BSO managed. => so if several walli controller are involved in the control of a device there is no synchro possible, and operation from the domotic interface (Yubi or HC3 or ....) aren't report on the walli controller - 2nd : walli controller ack with a green (or red if not ok) ring light of any physical order (clic) => within this time no ring setting could be performed, they are lost or incompletely applied, so i you set ring light within this time, this setting is lost - 3rd: walli controller (even wired) have capricious performance when included with security level => delay to execute order, refuse operation (red return), ring color not setted, no reaction on clic - 4rt: association with a zwave direct device is enable but isn't synchronise with application order => if the BSO is open with an application, the walli doesn't know this status and the 1rst clic on the button have no action on the remote device according with all this (little) knowledge i found tips to bypass the capricious system installed (before i found all that rules) tips 1 - all my devices managed with walli controller are included without security setting (i had to rebuilt all the config because i used security on my 1rst implementation) tips 2 - for light and BSO (other than dimming light) i don't use direct association (zwave) to control remote device (light or BSO) (pb 1, 4) => i always set the walli controller type as "scenarii" and i write for each light a single block to manage light tips 3 - for FGD212 (dimming light), no need to synchronise the walli and the device because of the way than the FGD212 is implemented, each clic on the walli send action to the FGD212 (single, double, long) so walli type is setted to "dimming" => zwave direct association (group 6) is allowed for each walli with dimming light, no walli association between themself tips 4 - for BSO (blind + slate) while pb4 i open case with fibaro support and the only answer was: manage your BSO with scene block , so i write 4 scene block * 1 clic upper button to open => scene block need to perform 2 actions : set slat position to 100% , then open the blind * 1 clic lower button to close => scene block need to perform 2 actions : set slat position to 0% , then close the blind * double clic on upper or lower button stop * long press on upper or lower button set to the slat to preferential position ==> 50% (or any position according with your need) Nota: don't use triple clic otherwise you couldn't exclude device tips 5 - for color ring state (pb2) i have 2 scene block (even with dimming light) : * colored with light XX ON => trigger is when light is ON and set value to "true during the defined time" * colored with light XX OFF => trigger is when light is OFF and set value to "true during the defined time" the work around for pb2 is to add a time (true during the defined time) in the section trigger condition (2s is enough) => with this tips the ack of the clic on the walli is display and therefore the ring setting is applied correctly. as the trigger is on the light and not on the walli the type of the walli doesn't affect the scene I hope all this tips could help, because this not obvious to find all of them and to let the system stable and reactive with the big config.
  2. I have a Dimmer 2 with security level S0 and tried to connect Walli Controller by the book and with the code I got security level S2 Authenticated and leaving it blank or 000000 security level was set to None. When associate the two devices it complain on different security levels. When Adding Walli Controller as described below it gets added with security level S0. Add device Zwave Button Advanced, uncheck ‘Add in S2 Security mode if device supports it’ Start Device will be added in security level S0 Walli Controller Tab Advanced, Walli configuration Operator mode: Dimmer/Roller Shutter Controller Tab Associations Endpoint 0, Group 6 Multidevice, Choice your ‘Dimmer 2’ devices.
  3. Version 1.0.0
    74 downloads
    Kilka ikon przycisku walli mojego autorstwa
  4. My venetian blinds is driven by a FGR223 as a driver and a walli controller FGWC-201 as button what are the parameter to set with the FGR223 and the walli controller to manage up/down with short cli/push and slat with long clic/push I tried 2 settings to drive completely the venetian blinds without success. 1rst setting: I set the FGR223 as a venetian blinds and perform a calibration (the module is marked as calibrated) then parameter are setted to - 152: 150 - 153: 1 - 154, 155: 10 - 156: 5508 - 157: 5376 I set the Walli controler FGWCEU-201: - type: venetian blinds (parameter 20=6) - direct group association: node.0 group 7, with multichannel with node(FGR223).1 with this setting i have 4 problems : pb 1.1: when i short clic on the button of the walli controler (short push) nothing append, i have to make a long clic to move up or down the venetian blinds, as far as i stop pushing the button the blinds stop. pb 1.2: when i push th button to rich the open position, after few seconds the blinds move by itself to rich the a position 10cm down. pb 1.3: when the blinds and button are waiting for almost several hour without interaction, i need to clic twice on the walli controler, 1rst clic with green response with no move, second clic with green with move (up or down) pb 1.4: how could i manage the slat ? second setting try with another association: - FGR223 as a venetian blinds and perform a calibration (the module is marked as calibrated) - same as 1rst try - Walli controler FGWCEU-201: - type: venetian blinds (parameter 20=6) - direct group association: node.0 group 6, with multichannel with node(FGR223).1 with this setting when i short the venetian blinds move up or down the final position, and another clic stop the move, but i have 3 problems - pb 2.1: when i push th button to rich the open position, after few seconds the blinds move by itself to rich the a position 10cm down. - pb 2.2: when the blinds and button are waiting for almost several hour without interaction, i need to clic twice on the walli controler, 1rst clic with green response with no move, second clic with green with move (up or down) - pb 2.3: how could i manager the slat only ?
  5. Hi all, If the Walli Controller is in the Power Supply mode, is it possible to have its LED ring controlled in the same way as for example on Walli Switch or Dimmer? I mean to have it on to work as night light, or change color via scenes etc. According to manual it seems that it is not possible, but if anyone has actually chance to test it, I would appreciate it :). Thanks!
  6. Zakupiłem Walli Controller. Niewiele w necie jest informacji na jego temat, więc trochę rzeczy mnie w nim zaskoczyło, albo nie umiem czegos skonfigurować, albo mam trefny egzemplarz. 1. Kolory świecenia diód po naciśnięciu przycisku zmieniają się tylko i wyłącznie w zależości od trybu działania. Tzn. w trybie kontrolera scen na zielono, w trybie podwójnego przycisku na czerwono itd. Zmiana koloru swiecenia diód w parametrach urządzenia nie przenosi się do kontrolera (tak, wybudzam go z trybu uśpienia). Czyli nie za bardzo mogę uzyskać białe podświetlenie. 2. Nie działa mi podłączenie pod zasilacz. Czy urządzenie jest faktycznie bardzo wybredne i działa tylko z zasilaczami SELV, LPS lub NEC klasy 2? Podłaczyłem pod zasilacz dopuszkowy 12V 0,5A (0-6W) i nie rozpoznaje zewnętrznego zasilania, czy zasilacz jest za słaby?
