Showing results for tags 'roller shuter2'.
  1. I've a number of roller shutter 2's operating Venetian blinds and they are working perfectly, and have for many years. Today I have moved one of them from my HC2 to my HC3. Set the mode to Venetian, ran calibration. I can open and close the blind but have no control over the slat position. That is in the Yubii app and the HC3 GUI, the slider is there so I know the blind mode is correct, but it does nothing. The relays in the roller shutter do nothing, not even a click. Just in case the issue is the GUI I've writen a block scene to move the slat position, still nothing. I have another 10 blinds to move over and this is not a great start.
  2. My venetian blinds is driven by a FGR223 as a driver and a walli controller FGWC-201 as button what are the parameter to set with the FGR223 and the walli controller to manage up/down with short cli/push and slat with long clic/push I tried 2 settings to drive completely the venetian blinds without success. 1rst setting: I set the FGR223 as a venetian blinds and perform a calibration (the module is marked as calibrated) then parameter are setted to - 152: 150 - 153: 1 - 154, 155: 10 - 156: 5508 - 157: 5376 I set the Walli controler FGWCEU-201: - type: venetian blinds (parameter 20=6) - direct group association: node.0 group 7, with multichannel with node(FGR223).1 with this setting i have 4 problems : pb 1.1: when i short clic on the button of the walli controler (short push) nothing append, i have to make a long clic to move up or down the venetian blinds, as far as i stop pushing the button the blinds stop. pb 1.2: when i push th button to rich the open position, after few seconds the blinds move by itself to rich the a position 10cm down. pb 1.3: when the blinds and button are waiting for almost several hour without interaction, i need to clic twice on the walli controler, 1rst clic with green response with no move, second clic with green with move (up or down) pb 1.4: how could i manage the slat ? second setting try with another association: - FGR223 as a venetian blinds and perform a calibration (the module is marked as calibrated) - same as 1rst try - Walli controler FGWCEU-201: - type: venetian blinds (parameter 20=6) - direct group association: node.0 group 6, with multichannel with node(FGR223).1 with this setting when i short the venetian blinds move up or down the final position, and another clic stop the move, but i have 3 problems - pb 2.1: when i push th button to rich the open position, after few seconds the blinds move by itself to rich the a position 10cm down. - pb 2.2: when the blinds and button are waiting for almost several hour without interaction, i need to clic twice on the walli controler, 1rst clic with green response with no move, second clic with green with move (up or down) - pb 2.3: how could i manager the slat only ?
