Showing results for tags 'slat orientation'.
  1. I've a number of roller shutter 2's operating Venetian blinds and they are working perfectly, and have for many years. Today I have moved one of them from my HC2 to my HC3. Set the mode to Venetian, ran calibration. I can open and close the blind but have no control over the slat position. That is in the Yubii app and the HC3 GUI, the slider is there so I know the blind mode is correct, but it does nothing. The relays in the roller shutter do nothing, not even a click. Just in case the issue is the GUI I've writen a block scene to move the slat position, still nothing. I have another 10 blinds to move over and this is not a great start.
  2. Hi, Here's a problem I can't get fixed. I installed an EVB (external venetian blind) and want to control it with the fibaro roller shutter module. I followed the instructions (and double checked them), but I can not rotate the slats. The only thing I can do is open and close completely (and stop and an intermediate position. Rotating slats is not possible. Does anyone has any experience with this issue ? Thanks in advance, Gunter Settings : Device EVB with positioning parameter 3 = 1 parameter 10 = 2 parameter 13 = 1
