FBerges 52
Hello
After I had a problem with my HC3 a few times and scenes and QA's were not edited, I think about self-monitoring or Whatsdog.
The error showed up as follows:
My neighbor came to me and said that my bell was probably defective.
Well, the measuring device and screwdriver were taken out and off we went.
But lo and behold, everything is OK, no hardware fault.
So software!
Scene opened as well as the debug window.
Like that, an error message unspecific, the thing is old and has no errors!
Inserted a REM line and saved everything OK, the thing works, REM out again Save and run!
Shake your head and wonder!
Controlled other scenes (there are some) and from time to time I had something like that.
Do the same and everything works again (I thought).
But the doorbell still doesn't go off ???
The QA who rings the doorbell, let's see and lo and behold, an unspecific error message so REM in and save, I thought, said done and the HC3 booted and no longer wanted to run.
Then wait a while for an auto-repair and go back to the Betta (I had it on the last time).
Now the system ran again immediately without grumbling or grumbling.
I let the system run for 4 days and checked everything OK, all scenes and QAs, but everything works.
Now back to the current version 5.050.13, it seems to have been running for 5 days.
This is very annoying because I have my alarm system and fire alarm system running on the HC3.
YES YES I don't know the right system but I thought that the functionality would actually be safer and at least an error message comes up.
Now to the real question, has a memory about self-monitoring and Whatsdog ever made?
I already have some ideas because you can't get to the system, you would have to solve it with LUA.
Hardware timers etc. are actually not a problem but who makes sure that the LUA is running.
I could imagine the hardware timer (retriggerable monoflop) and a lamp and / or buzzer that is triggered with an FGS-224.
That something like this is not provided in the HC3 amazes me because the HC3 has integrated an alarm system and a buzzer, lamp and timer do not cost any money compared to the HC3.
But as is so often the case, there are many roads that lead to Rome, and someone has a better idea.
The default is to check the QAs and the scenes whether they are running and whether the HC3 itself is still running.
Since you can't rely on FIBARO and testing yourself, you apparently have to do it yourself.
Since some companies read along here, people would still generate something for sales!
1, - € per device as a royalty for me! : wink:
Greetings Frank
Hallo
Nach dem ich nun einige male ein Problem mit meinem HC3 und ein nicht bearbeiteten von Szenen und QA´s hatte, denke ich über eine Selbstüberwachung oder Whatsdog nach.
Der Fehler zeigte sich wie folgt :
Mein Nachbar kam zu mit und sagte das meine Klingel wohl defekt währe.
Nun Gut Messgerät und Schraubendreher rausgeholt und los ging es.
Aber siehe da, alles OK kein Hardwarefehler.
Also Software!
Szene geöffnet wie auch das Debugfenster.
Wie das, eine Fehlermeldung unspezifisch, das Ding ist alt und hat keine Fehler !
Eine REM Zeile eingefügt und abgespeichert alles OK, das Ding läuft, REM wieder raus Speichern und läuft !
Kopfschütteln und wundern ist angesagt !
Andere Szenen kontrolliert (Das sind einige) und ab und an hatte ich noch so etwas.
Selbes Vorgehen und alles läuft wieder (dachte ich).
Aber die Klingel geht immer noch nicht ???
Der QA der die Klingel anwirft, mal sehen und siehe da auch eine unspezifische Fehlermeldung also REM rein und abspeichern, dachte ich, gesagt getan und der HC3 bootete und wollte nicht mehr laufen.
Dann ein Autorepair nach einiger Zeit warten und zurück zur Betta (Die hatte ich das letzte mal drauf).
Jetzt lief das System sofort wieder ohne Murren und Knurren.
Ich habe das System 4 Tage laufen lassen und alles OK alle Szenen und QA´s überprüft aber alles läuft.
Jetzt wieder zurück zur Aktuellen Version 5.050.13, seit 5 Tagen scheint es zu laufen.
Das ist sehr Ärgerlich da ich auf dem HC3 meine Alarmanlage wie auch Brandmelde Anlage am laufen habe.
JA JA ich weis nicht das Richtige System aber ich dachte das eigentlich die Lauffähigkeit Sicherer währe und wenigstens eine Fehlermeldung kommt.
Jetzt zur eigentlichen Frage hat sich schon mal einer Gedenken über Selbstüberwachung und Whatsdog gemacht ?
Einige Ideen hätte ich schon da man nicht an das System rankommt müßte man das mit LUA lösen.
Hardwaretimer usw, sind eigentlich kein Problem aber wer stellt Sicher das das LUA läuft.
Der Hardwaretimer (Retriggerbarer Monoflopp) und eine Lampe und/oder Summer der mit einem FGS-224 angestossen wird könnte ich mir vorstellen.
Das so etwas im HC3 nicht vorgesehen ist verwundert mich schon denn eine Alarmanlage hat der HC3 integriert und ein Summer, Lampe und Timer kosten kein Geld im vergleich zum HC3.
Aber wie so Oft, viele Wege führen nach Rom möglicherweise hat einer eine Bessere Idee.
Vorgabe ist, Kontrolle der QA´s und der Szenen ob sie den laufen und ob der HC3 selber noch läuft.
Da man sich auf FIBARO und das Selber testen nicht verlassen kann muss man anscheinend selber ran.
Da hier einige Firmen mitlesen, Leute das währe noch was zum Umsatz generieren!
1,-€ pro Gerät als Tantiemen für mich ! ?
Gruß Frank
Edited by FBerges0 answers to this question
