Bernhard Stockman 1
I have some Qubino smart meters and would like to get the power values from these. As far as I understand (beeing a newbee) polling could be done in three different ways
defined in the device advanced settings.
1. Polled att periodic intervals with specified polling time
2. Using the global polling queue
3. Exclude from polling (but using e.g. triggers)
Tried to figure out the details about this but nothing mentioned in Fibaro manuals like Home Center 3 manual or Lua Scenes manual so I did some experiments with all
three methods. (in case 3 I used a scene where the condition allways = true). The result:
/monthly_2020_11/Polling.jpg.04809a1f8bd2d6b27a6e891582dead92.jpg" />In the first case I have marked the 300 seconds polling with green. Obviously there are pollings done outside of the 300 second period. Have no idea why.
In the second case the polling delay varies a lot from 10 seconds to over 5 minutes. Have no idea why? Besides the Qubino Smart Meter I onloy have a
Fibaro Wall Plug so the load on the HC3 can not be that large.
In the third case the delay is mainly between 10 to 50 seconds so obviously this is the fast method. I guess that delays time may increase when
you add more scenes with isTrigger = true.
Conclusion. Compared to HC2 the HC3 misses a lot when it comes to displaying consumption. As a consequence you will have to do
a lot yourself. For this to work you need good and detailed documentation. Unfortunately that seems not to be the case e.g. when it
comes to the condition statements in scenes. I would like to have a detailed description of all possibel operators that can be used in conditions
and how they work. I have searched a lot but not found any such document. I have of course found a lot of specific solutions in this forum
where a variety of operators have been used but no general and complete description of what is possible to do.
If some Fibaro people in Wysogotowo read this it would be nice to hear if there are any plans for a more detailed and througout documentation
of the HC3 software. By the way, I assume the OS of the HC3 is some Unix variant as times are given as seconds from 1970. It would also
be nice to see the HC3 software upgrade plan (if any exists) and what these upgrades are planned to contain.
Bernhard Stockman
10 answers to this question
