Kouzco 4
Hi!
I have my house stuffed with electrical heated floors. They are all controlled by HeatIt Trm3 thermostats.
I use the floor sensor in all of them as I found that the room sensor was not good enough (the temperature varied too much with room sensor, even after calibration).
The trouble is now that the temp outside is getting colder, so is inside. The floor it self is always 22,5 degreees, but the room temp is 20.
Is there a way in HC3 to make a compensations for the temperature outside?
So the lower the temp gets outside, HC3 will compensate and add a little heat to counter it.
thanks!
K
