Joep 195
Hello, does anyone know if it is possible to read the trigger in a scene in HC3?
In HC2 you do
I want to create a scene to turn all lights off. I want to run in manually, but also I want to run it when triggered from a double-click on a dimmer pushbutton. When I double click I want to know the trigger so the scene does exclude some lights. When I run manually the scene must turn off all lights.
If it's possible I don't want to create two scenes, 1 for detecting the double click and run scene 2 that turns off the light with exclusions and 1 for manual start in the app. I want it with 1 scene only and read the trigger. I also want to know if a profile switch (and which profile) triggered the scene.
Is this possible? I can't find it.
Edited by Joepprofile switch added
5 answers to this question
